AC21 - GO and IFC properties
alemanda
Is there any way to set a GO using IFC properties?
if not, is there any way to translate IFC properties into ac properties?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
1 REPLY 1
In the Graphic Override Rules Dialog I do not see any criteria or field that would allow the use of IFC Properties.
I think on the long run GRAPHISOFT want users to use only Element Properties and not create custom IFC Properties. If they solve mapping stuff to Element Properties - like it could be done in case of IFC Properties - then Element Properties can fully replace IFC PRoperties in my opinion. But at this moment this capability is not present in ARCHICAD.
