AC21 - upper slab-stair's connection
alemanda
playing (and working) with AC21, I'm now facing some difficulties in how to make simple and common things.
Now I'm having issues modeling the simplest (for RC structure) upper-slab to stair connection without using SEO.
Can anybody help me, please?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
5 REPLIES 5
alemanda
I found a possible way but I think there's a malfunction or bug in the tool.
Look at the picture
AC27 latest hotfix
Win 10 Pro 64bit
There is something not right with your ARCHICAD version.
In the INT version, Monolithic Flights have a 4th Connection Type, which would provide the necessary settings to solve this connection type. See the attached image.
Also, there is some glitches in the interface, those gray circles should be overlapping parts of the Stair Section, not be to the left of them.
alemanda
Laszlo, he glitches are due to win7. In win 10 I don't see any issue.
The fourth connection appears when the stair ends with the treads. When it ends with the riser you have only 3 connections.
AC27 latest hotfix
Win 10 Pro 64bit
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hi All,
It is currently only possible to do that with SEO (the same settings you use in the first picture, but subtract the slab from the Stair). We plan to add a connection type like that in the future though.
Daniel Alexander Kovacs
GRAPHISOFT
alemanda
Hopefully in ac21 ...
AC27 latest hotfix
Win 10 Pro 64bit
