Lingwisyer
Guru
Column Slant - Rotate to Path
Hi all,
I am currently trying to array columns that slope perpendicularly to a path. The issue is that when I perform the array operation, the new columns are rotated to be parallel to the path.
Might I be missing something when I set the array, or might there be a way to rotate multiple objects at once by their local origins?
Thanks,
Ling
EDIT: I can't seem to replicate this issue anymore.
0 Replies 0
