2004-10-15
02:24 PM
- last edited on
2023-05-26
03:20 PM
by
Rubia Torres
2004-10-27 04:10 PM
Djordje wrote:I started using the option and Alt but this morning I went to rotate a copy of a library part and this was not available. This makes it a two step operation; first copy the part and then rotate. This cannot be what Graphisoft had in mind.
As I weaned mself off the Drag a copy and prefer the ALT and CTRL (OPTION and ALT for you) method as I can switch between the modes, I don't find this behavior is a problem.
2004-10-27 07:13 PM
Millard wrote:It works quite nicely over here:
2004-10-27 09:31 PM
2004-10-28 05:21 AM
2004-10-28 01:06 PM
rengarch wrote:I've already assigned Command D to drag a copy. This always seemed more mac like as Command D was always duplicate for a mac. This doesn't change the fact that you cannot drag a copy of an object in a section window; but as Djordje says you can use the alt/option key to drag a copy. I believe this is Graphisoft's way to force us to use the new method.
Go to System
Preferences/Keyboard & Mouse/Menu shortcuts to disable this system
shortcut, or assign a different shortcut for ArchiCAD/PlotMaker
Rita Eng
2004-10-28 04:02 PM
2004-10-29 11:35 AM
2004-10-29 07:03 PM
Maybe we old dogs should try to learn the pluses trick?Oh-- I've been enjoying the pluses trick since you first wrote about it. It's a substantial improvement - thanks for brining it to my attention.
