ARCHICAD 19 Announced
Today ArchiCAD 19 was announced by Graphisoft.
Find all information about it here:
http://www.graphisoft.com/archicad/archicad-19/overview/
56 Replies 56
Looking forward to June and its release.
sinceV6
The feature comparison looks very promising. Looking forward to "add multiple labels to an element", "point clouds" and the overall speed, among all the other listed improvements.
Best regards.
What about Mac RETINA displays?
abdelaziz
I hope the update of archicad 19 new improvement will bring a software architecture with its projection problem is severe (boolean does not work on 2D plane, gsm object located on several floors do can not be cut in the plane 2d this is serious) you should see the problem in front and adjust I'm tired of circumventing the brobleme
AMD Ryzen 5950x
AMD RX 9070xt
AC28
Thanks Graphisoft I like the direction taken with temporary point markers and guide lines as well as the Dimention editing and the surface painter and not to mention backround processing speed as well as all the other improvements.
Jere
I'm easy to please. The following two are intriguing to me: "New and Improved Label Types" and "Simplified Door / Window UI"
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
Jere,
Then you will be pleased to here that the 1 Label per element limitation is gone and you can attach as many Labels to any element as you wish.
The Labels have been reworked to display specific types of information about elements since now you no longer have to squeeze all kinds of info into one Label.
Steve Jepson
Yes. These new labels are going to change the way I do many things. They have the potential to make many things that were difficult much easier and reduce the amount of typing out notes for details. They are going to be used in ways no one has thought of yet. The multiple labels for a single object mean you can have one for ID #, one for a note that is off to the side, one that has everything you could ever want to know about the object.... many very cool things for use almost very where in the program. Very nice in 3D documents. I have samples to show but probably should not do that until after authorized to do so.
This should get you all excited for 19. Very good stuff is coming! Don't blow your software budget on other software until you have seen 19. I have no idea, but I expect it to come out about the same time as last year. ? I wish they would tell us so we can plan and budget for the new release better.
Show away - the NDA is now over.
