ARCHICAD 20 INT is released
You can now download it from GRAPHISOFT:
http://www.graphisoft.com/downloads/archicad/install/AC20/INT
5 Replies 5
TMA_80
thanks but shouldn't this link be updated,
cause this is the one that referred to in the ArchiCAD20 presentation main page:
AC12_27 |Win11_64bit|
KeesW
Got AC20 Int loaded but can only run in Demo mode. Loaded and activated the dongle for AC20. It works for my other AC versions but not for this new one. Any ideas?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
When you check your dongle with the license manager you will find it only has the license for 19 (and all older versions).
Graphisoft AUS haven't sent out the license upgrade to version 20 yet - should be some time after 25th July.
So for now it will only be in demo mode that you can use it.
The AC20 INT download link is now present on that page as well.
Yesterday, there has been an announcement from GRAPHISOFT that the global rollout has begun with the first 6 versions: INT, USA, UKI, GER, AUT and FRA:
http://www.graphisoft.com/info/news/press_releases/graphisoft-ships-archicad-20.html
More are on their way.
