ARCHICAD 21 - rail edit & 3D contours issue
Hi
I'm not sure if this is a bug, but if it is it is fairly minor.
I've been using the rail tool in ARCHICAD 21 is which is really good. However, every time I go into the "edit" mode, then go back out, the contours of my 3D view disappear, even when the 3D settings show they are on. I have to deselect contours, hit OK, then turn them back on, and they reappear.
Anyone else having this issue?
Ben
3 Replies 3
Do you mean that the "Show Contours" checkbox gets turned off somehow when you enter Railing Edit Mode?
Or is it something else. Could this be a graphics card driver problem?
Hi laszlonagy
It's not happening anymore! Must be one of those one off things....but what I was doing was:
1) I'm in 3D view. I can see the 3D contours as the "Show Contours" is on
2) I select my rail tool in 3D, and go to the 3D environment. The contours drop off, BUT the tickbox for the "Show Contours" is still checked
3) I exit the rail tool in 3D, back to my 3D view. Contours has still dropped off, "Show Contours" checkbox is still checked
Roopa A
How to customize panels in ac21.
Like different panel designs in stair panel.
Roopa A S
