‎2022-08-09
09:30 PM
‎2022-09-20
12:26 PM
Gordana Radonic
I installed AC26, Goodies 26 and the update 3010 USA Full. I see the Accessories Library 26 and the Accessories box checked in the "Available Add-Ons", but I can not find in the Design Extras menu, the Accessories ( Roof Accessories, Slab Accessories, Wall Accessories). Any comments?
Solved! Go to Solution.
‎2023-02-01 08:13 PM
The solution is not to have Goodies as a separate download. Just include it in AC.
Why is Goodies still a thing???
‎2023-02-01 08:26 PM - edited ‎2023-08-11 02:12 AM
"But we do NOT see that this is a massive set back from usability point of view"
GS....
‎2023-02-22 08:24 PM
Currently facing the same challenge as above. I cannot see the Accessories in the Customize Menus option. Yet it shows that it is loaded into ArchiCAD.
‎2023-02-23 02:26 AM - edited ‎2023-02-23 02:26 AM
What you need to do (unfortunately) is re-install Archicad.
The 'repair' option is fine - you do not need to un-install it first.
DO NOT start Archicad.
Install the Goodies.
Install the latest update.
Now start Archicad and all should be good.
‎2023-02-23 08:53 AM - edited ‎2023-10-15 01:34 AM
GS have stated that it is not important to their clients user experience and we can live it.
‎2023-02-23 11:08 AM
Hi Barry,
Thank you. The solution worked, however i run into a new error when i launched ArchiCAD after the above process. I am happy to have access to the new accessories, though i am not sure what i am missing. How do i resolve this?
‎2023-02-23 11:47 AM
The custom settings button is unaccessible.
‎2023-02-23 12:11 PM
You need to download and add the Accessories 25 library in to your project that's why it's saying the object is not available in the loaded Libraries.
‎2023-02-23 12:12 PM
You need to check in your Add On Manager to see which add-on is throwing up the error.
 One of the entries will likely be red.
‎2023-02-23 12:30 PM
This worked. The .lcf file had not been loaded. It is now working just fine. Thank you very much.
