Accessories not found after installation in AC26
arqperalta
I installed AC26, Goodies 26 and the update 3010 USA Full. I see the Accessories Library 26 and the Accessories box checked in the "Available Add-Ons", but I can not find in the Design Extras menu, the Accessories ( Roof Accessories, Slab Accessories, Wall Accessories).  Any comments?
Carlos J. Peralta
a r c h i t e c t
Peru - USA
AC 4.55 - 26
Asus i9, 64Gb Ram, Windows 11, 4Gb graphs
47 REPLIES 47
The solution is not to have Goodies as a separate download. Just include it in AC.
Why is Goodies still a thing???
AC26
https://www.zendsign.fr/
"But we do NOT see that this is a massive set back from usability point of view"
GS....
AC26
Marthar K_ Byomire
Currently facing the same challenge as above. I cannot see the Accessories in the Customize Menus option. Yet it shows that it is loaded into ArchiCAD.
ArchiCAD 27
MacBook Pro 16-Inch, 2019
2.3GHz 8-core Intel Core i9
16GB RAM 4GB AMD Radeon Pro 5500M
What you need to do (unfortunately) is re-install Archicad.
The 'repair' option is fine - you do not need to un-install it first.
DO NOT start Archicad.
Install the Goodies.
Install the latest update.
Now start Archicad and all should be good.
GS have stated that it is not important to their clients user experience and we can live it.
AC26
Hi Barry,
Thank you. The solution worked, however i run into a new error when i launched ArchiCAD after the above process. I am happy to have access to the new accessories, though i am not sure what i am missing. How do i resolve this?
ArchiCAD 27
The custom settings button is unaccessible.
ArchiCAD 27
You need to download and add the Accessories 25 library in to your project that's why it's saying the object is not available in the loaded Libraries.
Lee Hankins
macOS Sequoia (15.1.1)
You need to check in your Add On Manager to see which add-on is throwing up the error.
 One of the entries will likely be red.
Lee Hankins
This worked. The .lcf file had not been loaded. It is now working just fine. Thank you very much.
ArchiCAD 27
