Adjust Slab Thickness
How do you adjust the slab thickness setting? The setting is greyed out in the settings dialog box, i.e. the first setting in the Geometry & Positioning Tab, and I cannot see how to adjust it. Archicad v.10
Ted Taylor
If you have a composite fill selected for the cut fill for the slab, the depth will be greyed out. Either change the composite fill or change to a regular fill.
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
Ted thanks for the help, all ok again. I was surprised that this was not mentioned anywhere in the Archicad documentation as the default setting for the column was a composite fill! Thanks again.
