ananas
Adjust railing
Hi everyone,
Does anyone know how to adjust the railing so it stops at the desired endpoint? It’s currently extending a bit further than I need it to.
Operating system used: Windows 11 Pro 23H2
3 Replies 3
David Maudlin
ananas:
Take a look at the Ends settings. Be sure you have the correct part selected at the top of the dialog box.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
JeffH
Could also be this setting that needs adjusted
AC24 / AC26 / AC27
Win10
ananas
Hi, thank you both.
I found it:
Not sure why, but I could not set to zero, but first write a bigger number and then I could lower it ...
I have one more struggle.
I would like to align the edge with the other ailing bars, but now sure where to find this settings to push it a bit back?
