a month ago
Hi everyone,
Does anyone know how to adjust the railing so it stops at the desired endpoint? It’s currently extending a bit further than I need it to.
Operating system used: Windows 11 Pro 23H2
a month ago
Take a look at the Ends settings. Be sure you have the correct part selected at the top of the dialog box.
a month ago - last edited 3 weeks ago by Laszlo Nagy
Could also be this setting that needs adjusted
Hi, thank you both.
I found it:
Not sure why, but I could not set to zero, but first write a bigger number and then I could lower it ...
I have one more struggle.
I would like to align the edge with the other ailing bars, but now sure where to find this settings to push it a bit back?
