Align View
how do i use align view? Doing everything according to manual but camera is not being placed.
12 REPLIES 12
Djordje
nizar wrote:
thanks alot guys, need to try it out in photoshop, good to know its frustrating in AC
Try with Art•Lantis 4.5
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I'm having the same problem, if I place the points where I want them, I don't get a camera...I sure would like to be able to use this tool and not have to jump between different programs
zoom into your image and carefully draw 2 'vertical' lines over the image, that you know the height of
snap to the top and bottom points when using the align view command, following the instructions it gives you
works best with oblique views, 'head-on' views are too sensitive to be useable
