Alt-x ALt-y Alt-a and Alt-R constraints in 8.1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2003-11-20 07:17 PM
2003-11-20
07:17 PM
They don't seem to work, can I get them back?
And also is the Shift selection method in any tool that used to be until 7.0 version back?
BEst regards,
António Pina
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-20 08:31 PM
2003-11-20
08:31 PM
afpina wrote:They do work; however, they can be a bit slow to catch on.
What happened to Alt-x ALt-y Alt-a and Alt-R constraints in 8.1? They don't seem to work, can I get them back?
And also is the Shift selection method in any tool that used to be until 7.0 version back?Regretfully not
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-20 10:21 PM
2003-11-20
10:21 PM
If you start drawing, click the first point, go in a given direction and lock it with shift key, you won't be able to activate ALT+X or Y while maintaining the shift key pressed... ALT+A will work !
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-21 07:57 PM
2003-11-21
07:57 PM
Hmm. I can't get Alt + A to work while the shift key is pressed. All that happens for me is the "drag a copy" toggles on and off and the A keystroke is ignored. I can't tell you how many unwanted copies I've dragged since moving to 8.1.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-21 09:15 PM
2003-11-21
09:15 PM
I've noticed a strange behavior of AC : if other application have their windows opened in the background, AC won't consider the keystroke (F keys, etc). If these applications are not closed, but minimized, all shortcut keys are working !
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-22 08:57 PM
2003-11-22
08:57 PM
There is another factor -- and it annoys me to no end. All the shortcuts, including Alt+X, etc., are case sensitive. You must have caps lock turned OFF in order for them to work. This has caused me a number of headaches when try to annotate because I have to keep switching between capitals (for annotating) and lower case (for shortcuts). It bites!
