2011-10-10 08:11 PM
2011-10-10 08:24 PM
2011-10-10 09:09 PM
another Moderator
2011-10-10 09:47 PM
2011-10-10 10:00 PM
another Moderator
2011-10-10 10:12 PM
2011-10-10 10:18 PM
another Moderator
2011-10-10 10:29 PM
2011-10-10 10:40 PM
another Moderator
2011-10-10 10:45 PM
Also avoid to use external drives, which needs to be mounted. If you have e.g. an external Raid storage, which requires mounting on startup: disable - Start BIM Server with Operating System - check box in BIM Server Preferences, because if the BIM Server starts before the mounting happens, that can cause problems, so start the server manually after the external drive is mounted.
another Moderator
