ā2005-05-19 03:40 PM
ā2005-09-13 01:32 PM
oreopoulos wrote:What's even worse is that not even the API allows full access to the program's environment and functions. There is a lot that has to be done from scratch because you cannot get to the Archicad version,
There are many important features missing from archicad.
That is really bad.
We are in 2005, and archicad does not have a scripting environment.
You just have to use API.
ā2005-09-13 07:14 PM
Bruce wrote:Where would you be placing them in space?
It also needs the option to place and / or copy elements in elevation and section.
ā2005-09-13 11:19 PM
ā2005-09-14 12:04 PM
ā2005-09-14 12:49 PM
ā2005-09-14 09:55 PM
ā2005-09-14 10:26 PM
oreopoulos wrote:The only way I know if is the "draw a polyline, copy it to plan, magic-wand it with a slab, and save as an object" method.... yucky, but it works.....
And a question to Djordje
For example i need to decorate an elevation in 3d.
Justdraw an arbitary 2d shape and give it some extrude.
If i could draw the outline on the elevation (like i do with a slab) and give it some height, i could easily do it.
BUT now?
How would you do it, and how would you then easily edit it (like you do with a slab)?
ā2005-09-14 11:12 PM
TomWaltz wrote:That's what I typically do, too. Really fast once you've done it a couple of times, but not ideal at all.
ā2005-09-15 08:39 AM
ā2005-09-15 09:22 AM
