Widows have serious issues
i have a singlehung twin window that will not show shutters in the elevation or 3-d mode yet they are showing in the floor plan mode. i have checked all the parameters and they all say to have shutters and i even deleted the windows and used alt>click to select properties from another window and it still doesn't work. any help out there?
4 REPLIES 4
Try "cutting" all elements except section markers and then paste them back in place.
Dan K
In Door and Window Builder there is an option for various states of opening, eg. show open in 2D, closed in 3D, and you can vary the angle in each. Is there a setting like that with what you are using?
Djordje
Which library?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
it is the AC 9 standard library but the window must have glitched and is working now when i cut and pasted like dan said.
thanks
