help! rotate a copy quit working!
Its just all of a sudden not working, (multiple copies that is) any suggestions anyone, something obvious Im missing, (its not working on anything from either the floating window or the tools drop down, whats up!) Thanks for your help
-Joe
8 REPLIES 8
TomWaltz
It's not working, or it's not on the menu so you can pick on it?
Assuming you mean that it is there, but not working, does it do anything at all? Is there any chance the item(s) you have selected is on a locked layer? Or not in your workspace?
Tom Waltz
Djordje
-Joe
Press Control for ... a copy, Cotrol Alt for ... multiple
If it is not in the pull down, go to Options/Preferences ... the tickbox is there.
Changed Work Environments recently?
And, please include your ArchiCAD version, computer and OS details in your signature.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
__archiben
i have the 'a-copy' part drop out on me on a regular basis: i.e. pressing the ALT button, or indeed choosing '<Transformation> a Copy' from a menu simply doesn't work.
quitting archiCAD and re-launching clears it momentarily, but it comes back whenever i go to work in a particular sect/elev window. anything similar? i'm going to flick it off to GS tech support when i get the impression that they might actually give a damn about mac archiCAD . . .
~/archiben
b e n _ f r o s t
Yeah, its the same problem as you ~/archiben, cept Im on a pc, Restarting archicad fixed it, hope it doesn't keep happening, Thanks for the help guys!
-Joe
Greg A_ Blunier
Do you have any other applications running?
On my PC I used to have problems with drag-a-copy not working by keyboard shortcut (ctrl-shift-D) when my Palm Desktop was running in the background (it doesn't happen anymore with the most recent version).
On my Mac I sometimes have problems with Entourage running in the background disabling "shift" to select items or to constrain angles. (I've been told it has to do with Entourage trying to access Keychain or something like that, but quitting Entourage and restarting it seems to fix it temporarily.)
Greg
ArchiCAD 28 USA Full and ArchiCAD 22 & 7
Windows 11
__archiben
just resolved my issue a little more:
i was using teamwork, and although signed in with exclusive access many of the edit transformations involving the creation of elements simply didn't work in certain sect/elev windows. i.e. anything-a-copy, split, etc . . . the weird thing was that i could create elements in those same windows with a simple copy and paste. very laborious though. signing out and back in again fixed it up for the time being and i've sent a report off to the red fortress . . .
~/archiben
b e n _ f r o s t
~/archiben
We have seen this same issue in our office as well. I found that you do not have to completely sign out and back in. Changing your workspace without actually changing anything will bring back the functions as well.
__archiben
Millard wrote:
Changing your workspace without actually changing anything . . .
hungarian logic?
i thought that might do it, but i went for the 'deep clean' option just in case . . . .
cheers
~/archiben
b e n _ f r o s t
