Greg Kmethy
ArchiCAD 11 Hotfix (build 1086)
Dear ArchiCAD-Talkers,
We have released Hotfix 1086 for ArchiCAD 11. It applies to Commercial, Trial and Educational licenses, and is currently available for INT and USA language versions. To download the Hotfix, please use "Check for updates..." command in Help menu.
Before installing the Hotfix, please take a moment to read the Release Notes!
Files with hotlinked modules may open unusually slow for the first time, as a result of a critical bugfix. This is normal, and happens at the first opening. After saving such a file, you might notice that the file gets significantly smaller.
A note for Grid Tool users: This Hotfix is a must-have for Grid Tool users. It fixes several functionality bugs, as well as some frequent crashes.
Greg
Gergely Kmethy
VP, Customer Success, Graphisoft
42 Replies 42
Dwight
No problem with two sessions on a G5.
Dwight Atkinson
Rick Thompson
Dwight wrote:
The ones with fire coming from their heads or the grey ones?
The grey ones. I don't think the fireheads are evil, maybe confused relating to the earth, but not evil.
I can open another secession here.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
TDabney
So I'm the only lucky one so far? Anyone else w/an Intel Mac?
Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
TDabney
OK, this seems to be a WIBU driver issue. I quit my ArchiCAD session and now I can't start it back up w/out the same WIBU error message. I will investigate further.
Tom
macOS 12.7
Apple M1 Max
ArchiCAD 26/27
aahatimo
did this hotfix auto update anyones goodies?
mine are still all 7/24/07. the release notes states hotfix updates goodies.
http://tr.graphisoftus.com/downloads/DL's%20for%20GraphisoftUS/AC%2011%20stuff/AC%2011%20updaters/AC...
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
TDabney
OK, I went to the WIBU folder inside the ArchiCAD 11 folder and found the only thing in there was a zipped (compressed) file. I unzipped it - it was a WIBU installer - which I ran. Now everything works as it should. Could the hotfix update have done that?
Tom
macOS 12.7
Apple M1 Max
ArchiCAD 26/27
I have install the hotfix 1086, now the "OK" bottom disappear in the setup windows of the element attribuetes...so I unable to save the changes that I have made for materials, lines, fills. etc?, same problem with the layer settings.
some one has the same problem?
Dwight
The first guys in the pond always find the gators.
Dwight Atkinson
Greg Kmethy
Unfortunately, the Plot Setup dialog needs to be re-set after applying the Hotfix. This is a side-effect caused by a necessary bugfix. To learn more about this, please read:
http://archicadwiki.com/plotter_preferences
The article also describes how to recover the settings, in case you don't remember the settings.
Further Hotfixes will not cause such problems. We are sorry for the inconvenience.
I have also added this to the Hotfix Release Notes. Rick, thanks for pointing this out.
Greg
Gergely Kmethy
Greg Kmethy
Victor, are you on Mac PPC/ Intel MAC or PC? What language version?
(It is a good idea to include this information in your signature)
Gergely Kmethy
