Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
ArchiCAD 11 Hotfix (build 1086)
Dear ArchiCAD-Talkers,
We have released Hotfix 1086 for ArchiCAD 11. It applies to Commercial, Trial and Educational licenses, and is currently available for INT and USA language versions. To download the Hotfix, please use "Check for updates..." command in Help menu.
Before installing the Hotfix, please take a moment to read the Release Notes!
Files with hotlinked modules may open unusually slow for the first time, as a result of a critical bugfix. This is normal, and happens at the first opening. After saving such a file, you might notice that the file gets significantly smaller.
A note for Grid Tool users: This Hotfix is a must-have for Grid Tool users. It fixes several functionality bugs, as well as some frequent crashes.
Greg
Gergely Kmethy
42 Replies 42
Eduardo Rolon
AFAIK GS found the reason for the crashes and they are working on a hotfix. I already downgraded to be able to work.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
agroni
So when can we expect the Austrian version of the hotfix 1084???
cheers
The BIMster @ AllesWirdGut
Currently: Archicad 26
User since Archicad 6.5 (2001)
Barbara Sommer
Graphisoft Alumni
Graphisoft Alumni
Graphisoft has released the 1086 Hotfix a few weeks ago.
Please check within the Help menu one more time if your ArchiCAD is up to date.
Barbara Sommer
Technical Support Team
Budapest, Hungary
archicadwiki - the ArchiCAD knowledge base
