2013-05-07 05:18 PM
2013-05-09 08:24 AM
Bricklyne wrote:Bricklyne,
....and THANK YOU! THANK YOU! THANK YOU! THANK YOU!! GRAPHISOFT for finally fixing the correct display of SEO's on plan view!!!!!
I can't tell you how many times (even in the last few weeks) I've had to resort to the old work-around of saving a .jpg image file of the top view in Axonometric on the 3D window and then saving that image as a worksheet and then scaling it to the right size by referencing the floor plan through virtual reference and then finally using virtual reference again on the floor plan with that image to trace the correct SEO cut of a cut element just to have it display correctly on plan.
2013-05-09 09:21 AM
laszlonagy wrote:Turns out that it was a mistake on my part.Bricklyne wrote:Bricklyne,
Can you tell me which feature you are referring to?
Results of SEOs shown on Floor Plan? For which elements?
I might be wrong but I am not aware of such a new feature.
Or I might just be misunderstanding something.
2013-05-09 11:22 AM
2013-05-09 04:22 PM
rocorona wrote:I don't really want to use this thread as a venting thread or to complain since this otherwise seems like a solid release, but at the end of the day, isn't that still a work-around that involves you having to do, what the program itself should be doing automatically?
[OT]the old work-around of saving a .jpg image file of the top view in Axonometric on the 3D window and then saving that image as a worksheet and then scaling it to the right size by referencing the floor plan through virtual reference
why don't you save the view as .2DL from the 3d window in internal engine mode? It is in vectorial format and on-scale.
[/OT]
2013-05-09 04:39 PM
2013-05-09 05:02 PM
Mjules wrote:Nope.
Is there a way to download the trial version of ArchiCAD 17 before May 30?
Thanks,
Martin
another Moderator
2013-05-09 06:09 PM
Barry wrote:I second what Barry said.
Same old render engine in 17 I'm afraid.
Another wish for the 18 list.
2013-05-09 06:20 PM
laszlonagy wrote:HelloBarry wrote:I second what Barry said.
I am not aware of any new rendering engine being part of ArchiCAD 17.
2013-05-09 06:59 PM
2013-05-09 07:37 PM
