2013-05-07 05:18 PM
2013-05-12 11:26 PM
epiteszikon wrote:BIMx is included.
Hello. Thy AC17 is awesome. Thy only question is = The BIMx is mean = I do not have to buy tha single Bimx ? Two in One ? Thanks
2013-05-13 12:24 AM
2013-05-13 04:39 AM
2013-05-13 05:08 AM
Karl wrote:Examples:
The reference line for a wall, for example, "anchors" a space-critical surface of the wall (your choice of what you deem space critical).
2013-05-13 09:44 AM
2013-05-13 05:40 PM
2013-05-13 06:02 PM
Bricklyne wrote:laszlonagy wrote:Turns out that it was a mistake on my part.Bricklyne wrote:Bricklyne,
....and THANK YOU! THANK YOU! THANK YOU! THANK YOU!! GRAPHISOFT for finally fixing the correct display of SEO's on plan view!!!!!
I can't tell you how many times (even in the last few weeks) I've had to resort to the old work-around of saving a .jpg image file of the top view in Axonometric on the 3D window and then saving that image as a worksheet and then scaling it to the right size by referencing the floor plan through virtual reference and then finally using virtual reference again on the floor plan with that image to trace the correct SEO cut of a cut element just to have it display correctly on plan.
Can you tell me which feature you are referring to?
Results of SEOs shown on Floor Plan? For which elements?
I might be wrong but I am not aware of such a new feature.
Or I might just be misunderstanding something.
I saw one of the demo videos which seemed to indicate that Graphisoft had fixed the problem or bug wherein elements that had SEO operations performed on them did not show the cut at all in plan view forcing one to have to manually draw it for documentation purposes.
It seems like it was actually a Morph element they were showing with the cut since Morph elements display SEO cuts on the floor plan correctly.
For all other construction elements (walls, roofs, slabs, C/W's, etc) there is no cut shown unless you convert it into a Morph, I guess, which is kind of useless if still hope for that element to function in its intended purpose and especially if you have to modify it later on as a construction element.
So, my mistake.
We're still stuck with work-arounds to deal with that issue, I suppose.
2013-05-13 07:56 PM
another Moderator
2013-05-13 07:58 PM
another Moderator
2013-05-13 08:30 PM
Matthew wrote:I can assure you, now there will be even more wishes to wish for
Yay!
ArchiCAD 17. The Wishlist Edition!
