Archicad 16 problem SEO not working?
fuzzytnth3
I have two walls, one wall is a multi-storey wall and the other is a complex profile. When I do a solid element operation with the complex profile being subtracted with upwards extrusion from the multi-storey wall, nothing happens .
Any ideas or has anyone else hit this problem?
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
1 REPLY 1
fuzzytnth3
After a bit of fiddlying about trying various combos it would seem its because the fill for the complex profile included some curves. Once I removed the curves the SEO worked.
A tad annoying the manual doesn't say don't use curves and or the SEO doesn't let you
As you were it isn't the curves in fat it is the wall priority. The multi storey wall had a priority of 4 and the complex profile wall had a priority of 2. Made them both the same now all is well
