Archicad 24 ,Curtain Doors problem
Ramadan Kozhani
How to open doors 180 deegres in floor plan ,at curtain walls,i go to the opening settings but still dosen't fix the problem still the same idk.
The CW swing door has a setting 0-90. You can't go 180 by settings.
My teams always vote for a "blind wall" insert with a regular door that you can make it do whatever you want...
This way you can schedule it as well independently of the CW.
AC 7-26 (current 27)
iMac 3.6 Ghz 10Core Intel Core i9 / 12b GB / AMD Radeon Pro 5700 XT 16 GB / Ventura 13.4
https://globularcreative.wixsite.com/home
1 REPLY 1
