ā2021-07-30 12:02 PM
ā2021-08-26 11:45 PM
another Moderator
ā2021-08-30 12:35 PM
ā2021-08-30 12:47 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
ā2021-09-06 03:04 AM - edited ā2021-09-06 03:06 AM
Thanks for your clarifications around this new GS ID setup - clearly there are bigger things in store for future releases.
Can you please clarify the following statement:
What will happen if Archicad is not authenticated within 30 days?
Once the 30-day sign-in period expired, file-saving and Teamwork function will not work. Archicad will run in Demo mode.
source > https://community.graphisoft.com/t5/Setup-License-articles/Graphisoft-ID-FAQ/ta-p/304176
Seems to me that this does affect the operation of a properly licensed Archicad instance... since even though you have a license you can not use it to save your files or use TW after the 30 day period?
Unfortunately, this is reminiscent of the ill-considered changes made to the Bug reporter, which since AC24 needs to be force quit to not send your report.
Looking forward to your reply.
Daniel.
