Victor Baboi
Archicad 27 - Stairs missing from mod files with hidden design option set
As I’m trying to migrate to 27, I have a new issue with exporting stairs into mod files.
They are missing from the mod file if they are set on a design option that’s hidden at export time.
All other element types get exported, except for stairs. The issue appears in both publish and save as modes. The stairs get exported only if the design option is set to visible at export (either to a design option combination or just set to current using save as). Stairs from main model get exported, of course.
Filter elements is set to All elements in Save options.
See attached screenshot for reference. I tested it with a new file (Archicad 27 default template, not in teamwork).
Did anyone else encounter this?
Victor Baboi
TESSERACT ARCHITECTURE
AC 16-27 | WIN 11
6 Replies 6
James B
Thanks for the report, we have this in our system already, and discovered it also occurs in previous versions with Renovation - as Design Options use similar technology. We'll investigate it further.
James Badcock
leandro_cs
This problem still happens with 27.3 or 28.0.
Any update or roadmap on this?
James B
No update yet on this, I've been prioritising other bug fixes/crashes ahead of this for now.
But it's still on my list. And thanks for the reminder.
James Badcock
KB-at-CWA
This is still happening for me in Archicad 27. I have to relink the MODs to the Teamwork file for it to export the stairs correctly. This in effect makes the updating of hotlinks extremely slow. Is this bug being worked on still? Is it a priority?
Graphisoft Certified Archicad BIM Manager - AC6 to AC28 (not using AC29). macOS Tahoe
This problem is still there in 29!!!!!!
Please fix it. It is annoying when I am trying to do my modules using Design Options instead of multiple negative stories, and the stairs just don't make it through!
ArchiCAD since 4.5
Windows, Mac
James B
A fix will be coming for this in AC30.1 and should also solve missing stairs in hidden renovations too (not just hidden design options).
James Badcock
