Archicad and Grasshopper troubles
Antonio Borrero
HI everyone
I have installed Archicad 25 updated 2 and rhino 7 in my Mac but at the moment that I try to work with the connection I have no respond for example if I choose slab in the parameters section in GH, put the icon in the canvas and try to set one slab in Archicad, when I select the slab in Archicad nothing happens it is like Archicad not recognizing the command in Gh.
I wonder if some of you can help me with this problem.
Thanks
Kaj_AL
Hi!
I've had some issues with this as well. What I've figured out so far is that you can't have groups on in Archicad when setting things in GH. So even if it's only one element you're setting, try suspending groups and then do it again.
You can also try selecting your slab in Archicad, then going in to GH, and without clicking anything (because then it becomes selected in Archicad), right click your slab importer in GH and click set one.
Good luck!
/Kaj
Archicad 24-27 SWE
Dell Precision 5560, Windows 11 Pro
11th Gen Intel(R) Core(TM) i9-11950H @ 2.60GHz 2.61 GHz
Antonio Borrero
Hi Kaj
Thank you for your respond, I've tried with the solution that you told me but it's the same I Continue with the problem. If you have another option I'll appreciated.
Best
