Auto Dimensioning not on menu?
4hotshoes
Graphisoft help says to 1. select walls to be dimensioned. Then 2. Go to "Document > Annotation > Automatic Dimensioning > Exterior Dimensioningā€ I am not seeing this option in the menu. Why not?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
Automatic exterior dimensioning is a couple of lines down on the menu in your screenshot, as "Exterior Dimensioning..."
Richard
AC26 (since AC6.0), Win10
4hotshoes
Oh my goodness! I looked up and down for that and never saw that. Maybe it did not appear on the menu until after I selected walls? That is different than Help suggestion though. I wonder why?
Todd Oeftger
Yes, those menu items will be greyed out unless you have walls selected.
It could also be because you have a different Work Environment than the one used in any help file.
The command will still be greyed out but may be in a different location - take mine for example.
This is from 22 but I still have it as it was many versions ago.
I have my own custom Work Environment and just add any new commands to it so I do not have to 'change my ways' every version.
