2024-06-21 04:08 PM
Hey guys,
I have been working on this particular project of hotel and residence, is 30 story building, and has some detailed elements, like facade with horizontal cladding done with profile walls. But lately, performance is just poor. Drag and select take ages, deselecting is sometimes impossible, 2d screen is not responsive, 3d slow, but improved after i changed Graphic Card settings, is spinning more than is efectively working. Is a cocept stage, so, not a lot of composites.
And my machine is quite powerful:
Intel Core i9 14900k
64Gb RAM
NVIDIA GeForce RTX 4080
Should I send a file for analisys to a Graphisoft support team, since this is more time waiting and spinning than actively working. And we paid quite a lot for this licences, so, any advice would be nice.
Thanks,
Milan
2024-06-21 05:07 PM - edited 2024-06-21 05:17 PM
Try to merge the project (3d model) to a new file. Unfortunately you will loose all the view maps and layouts, but you will be able to check the performance of the 3d model. If it works then something is wrong with the initial file (library loaded etc)
2024-06-21 05:12 PM
I was thinking that too, but hell, layouts and views are more than model for me at least in this project!! 😞
I will reach the support team, to see if they can do something.
Thanks again for your help!
Milan
2024-06-21 05:18 PM - edited 2024-06-21 05:44 PM
If you have views and layouts there might be a workaround to delete the original 3d model (keep sections, elevations. etc)
and merge the second file again to the initial file. That way you keep views-layouts by just importing the model to the same position.
Again you will loose dimensions-labels connected to elements but if the performance is fixed then probably the problem is solved.
The whole idea here is to check whether something is wrong with the file because with a 14900 and a 4080 your pc is not the problem definitely.
Keep in my mind that there is a possibility the support wont't be able to do anything so you need a plan b......
Greetings
2024-06-21 05:43 PM
You are soo nice!
Thanks a lot. Indeed, performance decreased a lot in last hour. Makes me impossible to work into.
Even if i have to recreate all I cant handle this. Is soo annoying, makes me want to throw PC through window!
I will merge asap, to test roughly!
Cheers!
Milan
2024-06-21 05:46 PM
Do not forget to give feedback for other fellow users here.
Good luck.
2024-06-21 05:47 PM
Yes, sure.
2024-06-21 05:47 PM
Fro the 2004 archives - How to clean a file without losing the views
another Moderator
2024-06-21 05:48 PM
Oh, thanks a lot. Will try it!
2024-06-21 06:13 PM
An I have different Graphic Overrides, Layer Commbinations, Pens, etc... Should I import them first throu Attribute manager?
Cheers!
Milan
