Barrier free doors and elements
ananas
Is it possible to set doors, windows and other elements with minimum free area marked? Do elements include that funtion in any archicad version or what would be the way to set it up?
I normally combine them with the area tool, but would be great if it would be joined in one element somehow
Or would I need to create my personal element for that?
Thank you!!
Operating system used: Windows 11 Pro 23H2
Ricardo Lopez
Hi @ananas
You can set the Minimal Space for door, windows and certain objects (lavatory, WC, beds, etc). You can turn it on from MVO settings.
Check this link out from Archicad Help: Minimal Space
Regards
M. Arch. Ricardo López
AC17-27 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
Ricardo Lopez
Hi @ananas
Regards
Perfect, thank you! Did not know about this option.
Setup info provided by author
