2019-08-08 03:19 PM - last edited on 2023-05-26 02:12 PM by Rubia Torres
2019-08-09 04:10 AM
2019-08-09 09:09 AM
2019-08-09 09:12 AM
Erwin wrote:Yes, I forgot to say what to do with the main wall behind.
To add to the walls + roof / slabs: you can opt to have an opening (emtpy window type) in the mail wall or split up the walls depending on if the bay needs to touch the floor (and be added to the zone as part of the total surface area).
With proper set up building material strengths it is relatively easy to get the corner connections correct.
2019-08-10 09:07 AM
