4hotshoes
Beam Tool Not Cleaning Up Corners, Why?
I don't usually have this problem. Am I missing a setting? This is a footing created from a complex profile and the beam is level and flat.
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
1 Solution
DGSketcher
Legend
Check your Layer intersection group number isn't set to zero if the post above isn't the solution.
Go to post
2 Replies 2
felcunha
Check if Clean walls and beams intersections is on.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
DGSketcher
Legend
