4hotshoes
Beam not showing on any plans but will show in section
I have placed these TJI beams in a plan view and they don't show on any stories with the layer on, but they all show on the section. I am baffled as to why. I have tried changing many settings. Any suggestions?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
16 Replies 16
Lingwisyer
Guru
4hotshoes wrote:
I have the plan file in simplified form and reduced in size for any one to look at. I hope the link works. I am likely overlooking something simple. I know I can suck-up parameters and inject them into the beams working to make them visible on the plan, but I wanted to know what might be causing this problem.
https://drive.google.com/drive/folders/17r1f_CqSOlAVgJEZ9IfihjhukUQvY7xa?usp=sharing
No permissions
4hotshoes
No permissions
I am not sure if I can fix that. What other options do others use to post a plan file?
Todd Oeftger
4hotshoes
No permissions
I found a way to open permissions to anyone with the link. Try again.
Todd Oeftger
Lingwisyer
Guru
Their Floor Plan Display was different and would have prevented them from showing, BUT, even after correction, and changing the Overhead line pen from the default white, the beams did not show up in plan...
It would appear to be a bug. I changed the Floor Plan Display to All Relevant Floors and they show up. Changed it back to Home Story Only, and they remain visible.
Ling.
4hotshoes
Ling.
If this appears to be a bug, have you reported this, or do I need to?
Todd Oeftger
Lingwisyer
Guru
Whelp. I did not report it at the time, but I shall now. If you already have, oh well, more pressure for them.
Ling.
Lingwisyer
Guru
When you report a bug, and they reply with part of your solution that you included with the report...
