2019-12-12
06:49 PM
- last edited on
2023-05-26
12:26 PM
by
Rubia Torres
2019-12-16 02:26 AM
4hotshoes wrote:
I have the plan file in simplified form and reduced in size for any one to look at. I hope the link works. I am likely overlooking something simple. I know I can suck-up parameters and inject them into the beams working to make them visible on the plan, but I wanted to know what might be causing this problem.
https://drive.google.com/drive/folders/17r1f_CqSOlAVgJEZ9IfihjhukUQvY7xa?usp=sharing
| AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2019-12-16 02:30 AM
Lingwisyer wrote:I am not sure if I can fix that. What other options do others use to post a plan file?
No permissions
2019-12-16 02:40 AM
No permissionsI am not sure if I can fix that. What other options do others use to post a plan file?
2019-12-16 03:22 AM
2019-12-24 12:01 AM
Lingwisyer wrote:If this appears to be a bug, have you reported this, or do I need to?
TheirFloor Plan Displaywas different and would have prevented them from showing, BUT, even after correction, and changing the Overheadline pen from the default white, the beams did not show up in plan...
It would appear to be a bug. I changed theFloor Plan Displayto All Relevant Floorsand they show up. Changed it back to Home Story Only, and they remain visible.
Ling.
2020-01-15 02:28 AM
2020-01-28 07:55 AM
