License outage
Dear Customers, We are facing with an outage in our services in Azure. You may experience issues with the Azure-based functions, like licensing, BIMcloud SaaS, Learn Portal. We are working hard on this issue to make it fixed as soon as possible. Thank you for your patience.
2013-03-1912:50 AM - last edited on 2023-05-2412:49 PM by Rubia Torres
I am trying to get profiled beams (metal framed door headers FWIW) to transfer from one file to another. I have tried copy/paste, merge MOD and merge PLN. The walls and columns come in just fine but no beams no way!
I opened the MOD and the beams were there so it is a problem getting them in not out.
I finally got it sorted. For some reason ArchiCAD insists on setting the pasted/imported beams to "show on relevant stories only" thus CHANGING the settings from the source file. The quirk here is that the Revit source file that I HAVE to coordinate with has the typical mish mash of levels that the Revitiot operators don't realize should not ALL be stories. So even though the beams were ON level one they were not showing up there. The 3D problem was the story filter.
Nando Mogollon Director @ BuilDigital nando@buildigital.com.au Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes) More and more... IFC.js, IFCOpenShell All things Solibri and BIMCollab
