‎2006-10-25 02:39 AM
‎2006-10-25 03:57 AM
‎2006-10-25 04:24 AM
‎2006-10-25 04:35 AM
‎2006-10-25 05:24 AM
This prompted me to change my "Beam" object to have a PerpendicularExplain. If you can do this, are you changing it in a way that you can continue to use the beam function or does it now because only an object? If you can continue to use the beam function, how did you change it to allow perpendicular cuts?
option just like the roof tool which can be used as a substitute for the
beam tool and the wall tool in certain situations.
‎2006-10-25 05:38 AM
‎2006-10-25 05:40 AM
