Beams are visible in plan but not in 3D
ratnabhirud
Hello everybody,
In Archicad 17, when all beams are visible in plan on all stories, why the same are not visible in 3D view ? ( Attachment ) while only First Floor Beams are visible in 3D.
I checked everything.
Beams are having normal standard Building Material and having default intersection ID.
All beams are placed on First Story & then copied to other stories.
Any Help?
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
11 REPLIES 11
Glad it worked out.
I would still adjust the top of Walls below this stepped down portion to the bottom of the Core of the Slab above them.
I have a question related to this topic
I have the same problem, but I don't know exactly where I have to change something in Archicad in order to show every element of the construction
