Beams joint issue in elevation views.
dlee
Hi all,
I have 2 questions about beams. I am using 27v.
1.
I am using complex profile beams. I gave them some angles and then made them join each other. However, around 80% of them are working fine but few of them are not joining. I checked 3 dimensionally to make sure if they are actually touching multiple times but they are still not joining.
2.
Even if they are joining in the 3D view, when I go to the elevation view, another 10~20% of the beams are not join although they look like they are joining in 3D view.
Are these just glitches? or is there a way to fix it?
And could anyone tell me the general behavior that the beams do? to reduce the errors.
Thank you.
1 REPLY 1
Please show some images of the errors with cleanup.
