dlee
Beams joint issue in elevation views.
Hi all,
I have 2 questions about beams. I am using 27v.
1.
I am using complex profile beams. I gave them some angles and then made them join each other. However, around 80% of them are working fine but few of them are not joining. I checked 3 dimensionally to make sure if they are actually touching multiple times but they are still not joining.
2.
Even if they are joining in the 3D view, when I go to the elevation view, another 10~20% of the beams are not join although they look like they are joining in 3D view.
Are these just glitches? or is there a way to fix it?
And could anyone tell me the general behavior that the beams do? to reduce the errors.
Thank you.
Steve Jepson
Please show some images of the errors with cleanup.
