ā2008-03-01 10:43 PM
ā2008-03-01 11:15 PM
rune1980 wrote:You can try the "Fillet" command (using a small radius) for joining the two walls.
Hello, is it possible to bevel corner edges on walls, so that they are not 90 degrees sharp but a little bit round?
ā2008-03-01 11:24 PM
ā2008-03-01 11:43 PM
ā2008-03-02 12:00 AM
ā2008-03-02 12:15 AM
ā2008-03-02 12:20 AM
rune1980 wrote:You can bevel the inner corner too (see attached image). Just play with your wall as if it was a slab. For getting a correct display in 2d, you can modify the way wall end lines are showing.
Dwight that does the opposite way that i want? I want it to bevel on the inner corner and not outer..
ā2008-03-02 12:27 AM
ā2008-03-02 12:35 AM
ā2008-03-02 12:57 AM
