Bevel wall edges?
Hello, is it possible to bevel corner edges on walls, so that they are not 90 degrees sharp but a little bit round?
13 REPLIES 13
You can try the "Fillet" command (using a small radius) for joining the two walls.
Thanks adytc it works, but do you know whether it is possible to do it on one side only?
Dwight
You'd be using the polygon wall for that.
Dwight Atkinson
Dwight that does the opposite way that i want? I want it to bevel on the inner corner and not outer..
Dwight
Duffus!
You can do anything with the polygon wall!!
Dwight Atkinson
You can bevel the inner corner too (see attached image). Just play with your wall as if it was a slab. For getting a correct display in 2d, you can modify the way wall end lines are showing.
Cheers.
Adrian Tudoreanu
Dwight
The reason i posted that image is to show that the polygonal wall can now support window objects like a real wall can.
I remember a time when this was not possible, relegating the polygon wall to mere infill status.
Dwight Atkinson
Okay bout how would you do this quickly?
Dwight
Is this a metal angle?
For verticals, a slab, for horizontals, a custom profile wall and for general elements, an object - the L beams 11.
Dwight Atkinson
