Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Break a line and leave a gap
Is there a way to create a gap in a line like the break command in autocad? Breaking a line between two points.
1 REPLY 1
Have you tried the Split command? If you want a specific gap, either move the end node of one of the lines after splitting, or you can place a couple of guidelines and use a CTRL-click to cut the gap out.
Richard
AC26 (since AC6.0), Win10
