Tom Krowka
Brick & Stone wall
Is it possible to create a wall texture that consists of a combination of two textures? I need a 4 foot high wall that consists of groups of stone (Castle rock in the library) combined with groups of brick in a random pattern.
It would be nice if I had a photo of one, but I can't find one. Then I could scan it and just add to the library.
Thanks
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
10 Replies 10
Photoshop.
Tom Krowka
Don't have it, despair setting in. Don't want to buy and learn another program in time for this project.
Thomas@wkarchwk.com
www.walshkrowka.com
Link
You should consider getting it Tom - you'll find it very useful!
Here's an image of a building a modeled with multiple textures created in Photoshop... too easy!
Link.
I feel stupid on this one. Could you elaborate on the technique used in photoshop for this.
Tom Krowka
What he said.
Thomas@wkarchwk.com
www.walshkrowka.com
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Why not ArchiWall?
one of the provided features let the user utilize different rows of different material/texture...
Just an idea!
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Tom Krowka
Does Archiwall have the capability to mix different textures together into one pattern, rather than simply rows or columns of different textures.
Thomas@wkarchwk.com
www.walshkrowka.com
Link
What he said.
Well I just copy and pasted the stone blocks into one image. To get the different colors, I used the Image>Adjustments command in Photoshop, before pasting into the final texture. See the attached image.
Then I created an alpha channel, using the method described at http://www.escribe.com/software/archicadtalk/m25778.html . Then I applied these to walls around my project. Simple, really.
I haven't yet had the chance to use ArchiWall, but am a big fan of anything Cigraph, so am sure it would be a great solution.
Tom Krowka
Link:
That page no longer exists. Could the URL be incorrect?
Thomas@wkarchwk.com
www.walshkrowka.com
