Brick & Stone wall
Tom Krowka
Is it possible to create a wall texture that consists of a combination of two textures? I need a 4 foot high wall that consists of groups of stone (Castle rock in the library) combined with groups of brick in a random pattern.
It would be nice if I had a photo of one, but I can't find one. Then I could scan it and just add to the library.
Thanks
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
10 REPLIES 10
Photoshop.
One of the forum moderators
Tom Krowka
Don't have it, despair setting in. Don't want to buy and learn another program in time for this project.
Thomas@wkarchwk.com
www.walshkrowka.com
Link
You should consider getting it Tom - you'll find it very useful!
Here's an image of a building a modeled with multiple textures created in Photoshop... too easy!
Link.
I feel stupid on this one. Could you elaborate on the technique used in photoshop for this.
Tom Krowka
What he said.
Thomas@wkarchwk.com
www.walshkrowka.com
Fabrizio Diodati
Why not ArchiWall?
one of the provided features let the user utilize different rows of different material/texture...
Just an idea!
Fabrizio Diodati
Tom Krowka
Does Archiwall have the capability to mix different textures together into one pattern, rather than simply rows or columns of different textures.
Thomas@wkarchwk.com
www.walshkrowka.com
Link
What he said.
Well I just copy and pasted the stone blocks into one image. To get the different colors, I used the Image>Adjustments command in Photoshop, before pasting into the final texture. See the attached image.
Then I created an alpha channel, using the method described at http://www.escribe.com/software/archicadtalk/m25778.html . Then I applied these to walls around my project. Simple, really.
I haven't yet had the chance to use ArchiWall, but am a big fan of anything Cigraph, so am sure it would be a great solution.
Tom Krowka
Link:
That page no longer exists. Could the URL be incorrect?
Thomas@wkarchwk.com
www.walshkrowka.com
