2020-09-29
		06:34 PM
		2023-05-09
		03:49 PM
			Rubia Torres
2020-09-30 09:45 AM
2020-09-30 10:51 AM
2020-09-30 02:49 PM
Erwin wrote:
Our local reseller has made some dimensioning objects for this purpose that follow the typical method of documentation here, maybe check with your reseller if they have any tips / methods for this.
Can't say I've ever drafted the individual blocks. Nor do I know of any bricklayers that would bother to look at a drawing with individual blocks.
2020-09-30 03:05 PM
Braza wrote:thank you! i tried doing this and it worked!
You can create a symbol fill with your brick/block top view dimensions, apply it to a Building Material and set its orientation to "Fit to skin". Then in your floor plan, set your Partial Structure Display to "Core only". Finally you will have to set the origins of your walls to match your project specifications.
Haven't tried this, but I think it could do the trick.
Hope this helps.
2020-09-30 04:34 PM
2020-09-30 05:40 PM
				2020-09-30 07:47 PM
vdentello wrote:You mean the multiply command, right?
I do it with GDL objects and the Array function.
Erwin wrote:Yes. Here in Europe this seems surreal, but in countries like Brazil, Architects must be prepared to produce construction documents for self construction projects. I think this is the intent of the exercise. More like Ikea instructions.
2020-09-30 11:52 PM
vdentello wrote:
I do it with GDL objects and the Array function. Coding all the blocks in a single element makes it harder for "decisions" like wall joinings.
Plus, it won't allow easy selection of individual blocks for mapping like I had to do.
2020-10-01 08:25 AM
Braza wrote:Ouch, talk about billable hours for producing drawings like that
Yes. Here in Europe this seems surreal, but in countries like Brazil, Architects must be prepared to produce construction documents for self construction projects. I think this is the intent of the exercise. More like Ikea instructions.![]()
