Building Material Priorities between Slabs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-09-24
08:07 PM
‎2023-05-25
05:41 PM
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-09-24 09:27 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-09-24 10:25 PM
The materials that are not the same, and don't have the same priority number should not clean up.I'm a bit confused by your statement. When I said clean up I meant that there should a clear break governed by the priorities. As this image shows there is not, and instead there's two slabs fighting to be seen on the surface (top and sides).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-09-24 10:56 PM
This can happen anytime two materials are in the exact same plane.
What's wrong with using SEO to have one subtract the other to get a clear break in the materials ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-09-24 10:57 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-09-24 11:46 PM
Anyhow, one last point on workflow efficiency. Although I'm not modelling every single tile I often have to split the topping slabs for larger design moves. Every time this happens I have to redo the SEO on each piece that gets split off of the parent slab. When compared to drafting the topping slab contour and letting the PBC take over, all those little additional actions add up quickly for large scale projects. Thankfully, all remains status quo and is no more difficult than before. Only the expectations took a hit.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-09-25 04:18 AM
Maybe in a future version this will be automatic as well as it seems to be something they are working on.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-09-25 06:12 PM
Duncan wrote:Image from page 1392 of the AC17 Reference Guide outlines how Automatic Intersections work, shows SEO for Slab/Slab intersections.
Am I completely missing something or do two slabs with different building materials (priorites) not clean up when overlapped?
www.davidmaudlin.com
Digital Architecture
