Building different home
hey
how i can build this simply glass building
sorry i'm antiPRO in paint ;d
12 REPLIES 12
TomWaltz
I think we need a little more info
Tom Waltz
hmm
i dont need that building with dooors windows etc. just need know hot to build like that drawing
how to build wall or roof where is red line ?
Dwight
Were he still alive, American songster Johnny Cash would know what to say. He even wrote about it in his tune "A Ceiling, Four Walls and a Floor." (Describing the feeling Archicad users have after a weekend of overtime.)
In your case, you'd use A Roof and Three Walls. Trim the walls to the roof.
A perfect example of a task for the 3D view.
Dwight Atkinson
but if all 3 top points arent in similar high ?
Dwight
Placing the roof in the 3D window lets you place three points to establish the roof slope.
I've attached a view to indicate an easy way to find the bottom point.
The USA Manual has instructions on page 215.
Dwight Atkinson
all okei!
well done!
tx
hmm i do smth wrong
Dwight
Your first go-around with the roof points is to establish the slope plane.
THEN you must go around again to place them.
It helps to have real nodes to stick to when establishing the slope. that is why i showed the image with the shorter wall. Otherwise the roof can get lost in space.....
I'm working with you on this because it is tricky until you get the hang of it.
Sort of like not appreciating George Bush until he is hung.
Dwight Atkinson
damn still i cant
