ā2022-08-25
09:41 PM
ā2022-09-22
06:19 PM
Oleksandra Vakariuk
Is there a quick and easy way to create building pad without having to transform the original topo (creating a copy, layer etc...) (similar to revit building pad fonction).
Thanks a lot!
Solved! Go to Solution.
ā2022-09-22 06:42 PM
Hi there,
You can use Solid Element Operations (Select an Element > Right Click > Connect > Solid Element Operations) with your foundation slab, or create a slab to fit the shape you want and put it on a hidden layer. The Operation you need is Subtraction, the slab will be an Operator, and the mesh will be a Target. Later on, you can edit the slab and the change will be reflected in the mesh.
Oleksandra Vakariuk
Technical Support Engineerā2022-09-22 06:42 PM
Hi there,
Oleksandra Vakariuk
Technical Support Engineerā2022-09-23 10:09 PM
Thanks a lot
