Cabinet handles not showing in renders
Ive been doing some renders of a kitchen recently and even after turning handles on with the cabinets they don't show at all.
Any advice or something I might have missed?
5 REPLIES 5
David Maudlin
nonco:
If you are using Model View Options to show the handles, make sure that a named MVO with the handles on is part of the View settings for the 3D Window View that is generating the render.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Facing kinda same issue, can anyone help please?
Are you simply rendering what you see in the 3D window or are you using a Project map View to create the render?
If you are using the Project map View then as David suggested the Model View Option is saved with that view so make sure the handles are turned on in that MVO scheme.
If you are simply rendering from your 3D window and you can see the handles there then I am not sure what is happening.
Maybe the handle material has not been set up correctly for Cinerender.
It is most likely the setting that David mentioned above. See attachment...
Richard
AC26 (since AC6.0), Win10
Thanks for the help, It was in the MVO, works fine now!
