Cabinet handles not showing in renders
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2016-08-22 06:41 AM
2016-08-22
06:41 AM
Any advice or something I might have missed?
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-22 02:43 PM
2016-08-22
02:43 PM
nonco:
If you are using Model View Options to show the handles, make sure that a named MVO with the handles on is part of the View settings for the 3D Window View that is generating the render.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-23 05:15 AM
2016-08-23
05:15 AM
nonco wrote:Facing kinda same issue, can anyone help please?
Ive been doing some renders of a kitchen recently and even after turning handles on with the cabinets they don't show at all.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-23 06:07 AM
2016-08-23
06:07 AM
Are you simply rendering what you see in the 3D window or are you using a Project map View to create the render?
If you are using the Project map View then as David suggested the Model View Option is saved with that view so make sure the handles are turned on in that MVO scheme.
If you are simply rendering from your 3D window and you can see the handles there then I am not sure what is happening.
Maybe the handle material has not been set up correctly for Cinerender.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-23 03:55 PM
2016-08-23
03:55 PM
warrior212 wrote:It is most likely the setting that David mentioned above. See attachment...nonco wrote:Facing kinda same issue, can anyone help please?
Richard
AC26 (since AC6.0), Win10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-24 10:30 AM
2016-08-24
10:30 AM
Thanks for the help, It was in the MVO, works fine now!
